So I just uploaded a new calibration from my tuner and now I have a CEL for Secondary o2. I have an email and call into him, but thought I'd post this to see if I can figure this out asap.
Right now under the closed loop tab, closed loop is unchecked and secondary o2 is enabled. Also, I know I had lean protection on my last calibration, but now it isn't setup.
I have a turbo s2000 w/ aem wideband. Any thoughts?
Uploaded new Calibration now CEL
Re: Uploaded new Calibration now CEL
Do you have a secondary O2 sensor?
Figured it out.
Closed loop - unchecked
disable P0145 (o2 heater) - checked
secondary o2 sensor enabled - unchecked
No more CEL. As for lean protection, I guess it was never setup because to my understanding you can't utilize that feature with a pra calibration. Unless there was a way that my tuner figured out in my original map before the adjustments to partial throttle. I'll have to ask him.
Question. Is there a loophole/workaround to get lean protection to work or replicate lean protection by adjusting other parameters/protection using an aftermarket wideband (AEM)?
