No FTP sensor with PRB K-pro for obd2 scan
STiness101
Post by STiness101 »
Hey,
I had a quick question. Im going to be installing a k-series in my 96 integra but i know that these cars do not have an FTP sensor in the tank and I am worried about throwing a CEL with a PRB ECU. I know I can disable it in the kpro but I want to be able to have the ability to scan for OBD2 readiness codes or at least with all the obd2a.
Would a JDM PRC ECU be able to work with the readiness check on OBD2 as I know that that ecu will not look for the FTP sensor? I don't know if it looks for the secondary 02 sensor or not or if it passes all the other US spec readiness codes.
Thanks!
Re: No FTP sensor with PRB K-pro for obd2 scan
Disabling the error code does not keep you from checking error codes.
STiness101
Oh ok, so if I would go for smogging it, all the readiness codes would show up with it disabled?
