H22 turbo passed emisssions
megomaniac
Post by megomaniac »
walbro 255
id1000
.82ar 67mm t3
3inch down, ceramiac high flow no name cat,
vibrant ultra quiet resonator, big magnaflow muffler
synapse turbo h22 manifold,
heat wrapped mani, down, and wrapped the cat too.
no egr, purge, iacv, fitv.
golden eagle im
shell 91
fresh oil
cut it really close, Nox limit 505, reading 504ppm
not tuned above 4500rpms
edit: took car for dyno tune and it locked up! oil flow to crank was plugged! fu*k you custom design performance,
so... another crank, rods, rings, align bore and hone...... and heres the map I'm on now
H22A4
turbo
S300
megomaniac
Re: H22 turbo passed emisssions
updated, rebuilt and running again...
H22A4
turbo
S300
