logging Lambda instead of AFR on Ethanol
Posted: Thu Jun 16, 2011 6:52 am
Hi Guys,
I would like to change from gas to ethanol but I'm not sure if I should use AFR or Lambda.
I'm using a NGK AFX wideband right now and know that if my wideband display varies from what Hondata is showing I have to change the voltage compensation so I can match the wideband's display with what hondata is logging.
What do you guys recommend to tune on Ethanol, AFR or Lambda?
Will my NGK AFX read the same values on both fuel types? I ussually tune to a 11.5 AFR on C16 on my NGK AFX, do I need to shoot for the same values on Ethanol if I keep my NGK AFX?
If you prefer to tune on lambda, how do you guys know if you have a wideband that displays AFR that you are logging the correct lambda values if you are using Ethanol instead of Gas?
