kpro/ignition online. but no datalog
eptwah
Post by eptwah »
car has been running great for over a month now with kpro. now after 5 seconds of turning on the key i get a CEL. tried checking it at autozone and it wont show up. Kpro wont show any response at all besides when i turn the key on. It recognizes the ecu but no response.
1.4.5.7 kmanager
02 civic si ep3 w/ k24a1 swap
Re: kpro/ignition online. but no datalog
Clear security and upload your calibration again.
You should also check your swap harness and engine grounds. http://www.hondata.com/techk20swaps.html
eptwah
Post by eptwah »
Hondata wrote:Clear security and upload your calibration again.
ok i cleared security and re-uploaded the cal. I even unhooked the battery for a few hours. problem still exists. The cel will not come one until 5-10 seconds after start up. and when I get the code read it shows no error codes. Could the ground to the valve cover be critical to this issue? I haven't regrounded it yet but im gonna try it now and see if it helps.
eptwah
Post by eptwah »
cleared security again and re uploaded the calibration. regrounded to the valve cover. re checked spark plugs and they are the correct ones. the car runs but it wont let me rev past 4k :(
eptwah
Post by eptwah »
also im throwing a code p1298. is it possible the eld is causing kpro not to work correctly?
Send an email to support <at> hondata.com with a high quality in focus picture of the inside of the ECU and a link to this thread.
eptwah
Post by eptwah »
Spunkster wrote:Send an email to support <at> hondata.com with a high quality in focus picture of the inside of the ECU and a link to this thread.
email sent.
i also noticed the mil lights up and stays on after turning the key to the on position. it takes about 10 seconds after turning on the key. so with the motor off and the mil illuminated. what could this be?
eptwah
Post by eptwah »
bump for help? I can't even find anything on the internet on a problem like mine.
