Tps problems
ldbriggins
Tps problems
Post by ldbriggins »
I have been noticing my tps on my hondata s300 datalogs a fluctuation of 1% and 2% at idle and at wot with my foot on the gas it shows 99.98% sometimes it dips to 75% and the car slows down then picks back up. Psi is steady even when i see the tps fluctuation. My plugs are new and are gapped at .24 or .25, thats didnt seem like the problem. With symptoms explained would one say my tps is going bad and has dead spots?
'Boom, Dunnit'
TheWickedOne1
Re: Tps problems
Post by TheWickedOne1 »
ldbriggins wrote:I have been noticing my tps on my hondata s300 datalogs a fluctuation of 1% and 2% at idle and at wot with my foot on the gas it shows 99.98% sometimes it dips to 75% and the car slows down then picks back up. Psi is steady even when i see the tps fluctuation. My plugs are new and are gapped at .24 or .25, thats didnt seem like the problem. With symptoms explained would one say my tps is going bad and has dead spots?
Recalibrate your TPS in the software and/or try another TPS and make sure that its installed correctly.
ldbriggins
Re: Tps problems
I recalibrated it like 30 times lol even then it doesnt explain the fluctuation at idle reading 1% or 2% its set at 0% in s300 and wot is 100.48% ill try a new tps soon.
'Boom, Dunnit'
ldbriggins
Re: Tps problems
here is my datalog
'Boom, Dunnit'
ldbriggins
Re: Tps problems
here is my calibration
'Boom, Dunnit'
ldbriggins
Re: Tps problems
Fixed it was my injector dead time..
'Boom, Dunnit'
tweenpix
Re: Tps problems
Post by tweenpix »
you fixed problem with fluctation of TPS?
