Stall at 5000rpm
Posted: Mon May 23, 2011 7:43 am
by VTiSpec
when I hit the pedal fast to WOT engine will go to around 5k rpm and stalls. If I hit it progressively it goes all the way up to 8k or more. it does that stationary and rolling.
I did datalogged it, but i forgot to saved it, anyway what called my attention, duty and inj were 0, but tps was around 85 as well as rpm 4800.
Re: Stall at 5000rpm
Posted: Mon May 23, 2011 10:25 am
You need to post the calibration and a datalog showing the problem.
Posted: Mon May 23, 2011 1:44 pm
by VTiSpec
I have to do that tomorrow afternoon, in the meantime I forgot to add that afterward I disabled "Lean Protection 1" and tested ok stationary, but rolling when I change gear engine stalled.
Posted: Tue May 24, 2011 10:46 am
by VTiSpec
attached calibration, I don't see the need to send datalog since it does not stall anymore. Engine hesitates when shifting gear (as I mentioned in my last post). this is a race car.
thanks,
Posted: Tue May 24, 2011 11:05 am
by VTiSpec
additionally,
B16A2 engine
83mm bore pistons
type R head
310cc injectors
stock cams
do you still want a datalog during shifting?
