How to Play with Fuel tables...
HondaTechn303
Post by HondaTechn303 »
Hello Their,
I have a '95 Civic Sedan with B18C1, CTR Cams(In. & Ex.), 2 1/4 inch Exhaust, B16 Trasmission.. Nothing made for race.. My question is How do I adjust Fuel Trim tables, I'm running alittle lean. I want to learn how to use this product.. I just want to get better MPG....
HondaTechn303
Re: How to Play with Fuel tables...
Trying to upload a data log file, Can't seem to do it, says message contains too few characters..?????
http://www.hondata.com/stech.html
Look at the tuning guide.
HondaTechn303
How do I adjust though???? I have squares that show -32% WTF does it mean??? Do I have to give it 32% less fuel??? I don't understand the Cal. fuel trim?? I have not modified Fuel Press. Why do I have to Cal.. Fuel trim if I have stock components?? Help!!!!!!
HondaTechn303
Honda Specs for Fuel Press. is 39-46psi, How would I adj. the "Overall Fuel trim" What do I enter for Old and New? My Fuel Press. now is 41 psi.. I don't know how to Adj. the Tables.. When I data log, I see a lot to -31% to -42%. How do I adj. this??? Do I adj. this by just typing in -31% to adj????
HondaTechn303
I apologize for all these ???s I have, I'm just use to working on Vehicles at the Dealer without having to do anything to the ECU... Now that I got this sys for me, I wanna learn... To me it seems difficult... Our "MAP" values are in Volts, is their any way to change these settings to voltage??? Fuel trim(Short & Long) are also in Volts???
Luke
Post by Luke »
you should start reading, what fueling is all about.
what the AFR is, how it should be, what timing is about, what the fuel trims are for.
after you have a clue about that, you can start adjust it by pressing ctrl+d or ctrl+i ;)
best regards Lukas
HondaTechn303
It's not that I don't know Fuel, Timing & A/F Ratio... Its just playing with the tables... We don't do this at Honda.. I bought this for myself to play with... American Honda doesnt let us Honda Tech mess with ECU maps....
