I hope this is the appropriate place for a feature request!
I'm a total noob with this tuning bit so perhaps I'm approaching this the wrong way, but hear me out. I'm running a stock '11 si with the tuned MAF base calibration. I've dialed in (I think) the AFR's and have been scaling back the ignition timing but have not successfully dialed-out reproducible-knock on 6th gear 75mph uphill (or during WOT) conditions. (I can also get it by WOT in 6th at some lower rpms.) I noticed that the MAP calibrations have the option to retard the timing per gear. I figure (I can code) that should be an easy addition to the MAF/AFM code that would make me pretty happy!
If anyone has any other suggestion for this, I'm all ears.
Thanks!
Edit: Just noticed that (again, with AFM) the WOT table does not seem to be controlled by MAP. I have a data log where I'm at MAP=950mbar, RPM=3795 and it is still in closed loop. For that data log, I was using the standard "tuned stock" MAF WOT determining pressures. I suspect that if that was functioning properly I could get away without the gear compensation.
AFM ignition compensation
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
