Help!!!!!!!! Need base map
Posted: Wed Feb 25, 2004 4:36 am
by vti2
Hi i?m loocking for someone that can help me with my base map, i made one my self but i?m not sure how good it is.
It is my first time that i make a base map and i don?t want to screw my engine up.
I have a Fully build B16
With :
Bensons Sleeves 84mm bore
CP pistons 9:1
Pauter rods
Crower valvetrain
Vitctor X intake manifold
T3/60-1 turbo with a stage 5 wheel .69 AR turbine and .70 AR
Full race manifold
3" exhaust
880cc injectors
fully 3" exhaust
2,5" IC pipes
Walbro intank fuelpump 255lbs
I?m trying to mack 500whp with the setup, my problem we don?t have any Hondata dealer in Germany, so there not to much people that can tune it and help me when i go to a dyno, i will also pirchase a wideband sistem and a EGT gauge i think i will need it to tune it.
I have a S200B stage 4 with a P28 ecu.
Please let me know iff you can help me.
Posted: Wed Feb 25, 2004 4:08 pm
by CivicVTi
You can try the available tunes for boosted b16a's. Just keep an eye on the EGT and wideband and you should be ok. Gradually increase boost. Keep your ears open for signs of detonation. Good luck.
p.s Very good setup.
Posted: Wed Feb 25, 2004 10:47 pm
by RMS
tune one boost column at a time and resist the urge to skip to the higher ones right away...slow and easy for the inexperienced tuners (dyno time is MUCH cheaper than breaking your nice engine). also, use c16 gas when tuning above 15psi; you'll need a lean mixture to approach the whp numbers you're hoping for.
Posted: Thu Feb 26, 2004 3:07 am
by vti2
what is C16 gas??
Posted: Thu Feb 26, 2004 6:19 am
by DaX
Leaded race fuel.
Posted: Sat Feb 28, 2004 7:09 am
by vti2
I think i don?t need race fuel, my car will be daily driven and in Germany we only have 100 octane pump gas.
