Problems connecting with ECU
K20EK4
Post by K20EK4 »
Hello evryone
I have a EK4 with a K20 in it.Hr harness and Pra ECU.
When i connect the ECU to my laptop the only thing that i can click is the blue info button that tells me what ECU and firmware i have and so on.
It says that it is online and the ignition off,even though that it is on.
What could cause this?
Re: Problems connecting with ECU
Most likely improper wiring. Try the ECU on a known good Vehicle. If you do have faulty wiring it is possible that you have damaged the ECU or the FlashPro.
K20EK4
Post by K20EK4 »
Is there anyway to fix this?or do i have to send it to you?
Have you tried it in another vehicle?
K20EK4
Post by K20EK4 »
I will go to my buddy and try it out as soon as i can.I will get back to you
