Datalog running problem
Posted: Tue Apr 19, 2011 11:37 am
by djzoli
Hi,
Please help me.
I have problem with datalog running.
If I start the datalog few second is work fine, after this frozen the tables.
If not frozen, then A/F ratio is always everywhere 17.5. (The o2 signal is 3,8V).
I downloaded and installed new softver versions but the problem is same.
My computer softver is Windows 7.
Posted: Tue Apr 19, 2011 12:16 pm
Are you using resistor or non-resistor spark plugs?
Posted: Tue Apr 19, 2011 10:55 pm
by djzoli
I using resistor spark plugs: NGK BKR7E
But I use MSD ignition system.
MSD 6A ignition control
MSD Blaster SS coil
MSD cap
low impedance spark plug wires.
If this is the problem, what I do?
Posted: Wed Apr 20, 2011 9:22 am
Try using all OEM components as it is very common for aftermarket parts to create a lot of interference. Use a stock distributor, cap , rotor and plug wires.
