Problem with P28 S300 in D16Z5 D16ZC
Posted: Sat Apr 16, 2011 4:38 am
by Trooper!
Hello i am a german so my englisch is not the best. sorry.
My problem is: I socket my P28 with a S300. i install it with an coversation harness OBD1 to OBD0. The ECU communikate with the engine. i can see all details at the smanager. i use the d16supercharger12ohm.skl from Hodata.
But the engine do not start! can someone help me with my problem?
can someone give me an finisched data? for my setup: stock d16z5 dohc engine, stock injektors, garrett gt28rs, and an 3" exhaust and an 2" at cat up to the end.
Thank you all for your answers.
Posted: Mon Apr 18, 2011 9:20 am
You do not have a heat sink on the voltage regulator and this will cause it to fail very quickly.
The calibration you are using is for 440cc injectors not stock.
