Problem with P28 S300 in D16Z5 D16ZC
Trooper!
Post by Trooper! »
Hello i am a german so my englisch is not the best. sorry.
My problem is: I socket my P28 with a S300. i install it with an coversation harness OBD1 to OBD0. The ECU communikate with the engine. i can see all details at the smanager. i use the d16supercharger12ohm.skl from Hodata.
But the engine do not start! can someone help me with my problem?
can someone give me an finisched data? for my setup: stock d16z5 dohc engine, stock injektors, garrett gt28rs, and an 3" exhaust and an 2" at cat up to the end.
Thank you all for your answers.
You do not have a heat sink on the voltage regulator and this will cause it to fail very quickly.
The calibration you are using is for 440cc injectors not stock.
