fuel injector code?
cecilseahawks
fuel injector code?
Post by cecilseahawks »
I ran my car on the dyno when I first got my hondata and threw a fuel injector code as soon as I turned on the car. When I plugged my stock b16 ecu in the code disappeared. The tech disabled the code and went on with the tuning. Does anyone know why this could have happened and is it any kind of danger?
94 del sol
B18c1 block, b16a head
.25 spoon balanced jdm itr pistons
skunk2 stage 1 cams
p&p
Injector code
There no problem disabling the code, but you should investigate why it occured. It is normal for JDM ECUs since they do not have the circuit to check the injectors. What injectors were you using?
cecilseahawks
I hae the stock b16 injectors, although one was replaced with a gsr fuel injector, but I dont see why this would be a problem. You are probablyu right about the jdm ecu because I beliee we started with the jdm gsr as the base program.
94 del sol
skunk2 stage 1 cams
p&p
