fjo and 4b
fjo and 4b
does anybody use fjo wide band o2 sensor and stage 4b? im looking for the correct voltage-airfuel values... please help thanks..
boosted hybrid
- Contact:
I just got off the phone with FJO.
There is a Square 4 wire plug connected to the FJO controller. There should be some Lettering on these connectors listed A,B,C,D. The colors coming out of the controller into the 4 wire plug are as follows(some of the FJO units have different wire colors so make sure you pay attention to the Lettering as well):
top of Plug:
AB
DC
Wire colors and Destination
A - Red - 02 Signal - connects to D14 in a OBD1 ECU
B - Green - Signal Ground - connects to D22 in a OBD1 ECU
C - White - connects to 12V Ignition
D - Blk - connects to Chassis Ground
If you are using a Dummy Honda plug from an old O2 sensor connect the letter A wire(red) to the White wire on the Honda Plug and the Letter B wire(Green) to the Green wire on the dummy plug.
There is more involved in getting your FJO to work in conjunction with your Hondata System but please refer to this article for the rest...
http://www.hondata.com/techwidebandtuning.html
top of Plug:
AB
DC
