random engine shut down
Posted: Wed Apr 06, 2011 9:32 am
hi all.
i have a 92 civic b16a2, fully built, with crower stroker kit and a garrett gt3076 turbo. car ran great for a long time now, but on saturday morning, i turned the key, and the fuel pump didn´t go on. at the 2nd try it worked. let the car warm up at idle for about 2 mins, and started to drive. but after 200 meters, the engine stalled. when i switched on the ignition, i heard the main/fuelpump relay and the fuelpump switch on-off very fast, and the mil stayed on. but i do not have an errorcode on my s300. also the led at the usb is red. but after a few times turning the key on-off, the runs great again.
this happens when the car is warm, cold, standing still, when driving, or just over night.
i have changed the main relay -> no change
checked the ignition lock -> no change
the grounding at the thermostathousing is perfect, but when i disconnect it, everything is still working!? isn´t this the main ground of the ecu and the main relay??
and yesterday, when i checked everything, i plugged of the usb from my carpc to the ecu, and it worked. but later i did the same and it didn´t help.
does anybody have an idea what can cause this?
the datalog shows it when it happens, but it´s loosing connection, when this happens.
thanks for trying to help!
i forgot to tell, that i was driving for 4 hours without problems yesterday, and after a stop at the gasstation, it happened again!!
