JRSC Hondata
Civicman
JRSC Hondata
Post by Civicman »
I have a 2000 Honda Civic Si with JRSC @6.5psi, i/h/e, and fuel pump.
I wanted to get the preprogramed Hondata and injectors offered from Jackson Racing.
Is there a wiring harness that lets me keep the OBDII or does my ecu get replaced with the OBDI? Also, are the maps set for 6.5psi, 8.5psi or 11psi? I wanted to get a 8.5psi pulley when I install the Hondata. Do I need a dyno or datalogger or ROM Editor to install it?
Sorry, I'm kinda new to the Hondata.
Russ
00 JRSCed Civic Si
Javier
Re: JRSC Hondata
Post by Javier »
AndyE
Post by AndyE »
I'll hit the bullet points here, but you definitely should go read through Hondata's web site (including the link above). All of your questions are answered there.
The original OBD-II ECU gets yanked and placed on a shelf (or sold, though not many people want 'em). In its place goes a modified OBD-I ECU with a Hondata ROM that connects to your original wiring harness using an adapter.
One set of fuel/timing maps will handle varying boost levels--higher boost just takes you into higher MAP columns, adding more fuel.
You don't need a dyno nor datalogger/ROM Editor to use the Hondata JRSC kit. However, you REALLY REALLY should get your car dyno-tuned by an experienced Hondata tuner. The Big Boost maps are the best I've seen for an out-of-the-box map, but every car is different, and the maps as provided won't match your setup perfectly.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
