b16 base map 1000cc injectors precision 6262
larryswansonite
- Contact:
what i got is erl sleeved b16a 84.5mm wiseco custom pistons 9.3.1 eagle rods eagle crank precision 1000 injectors with the little box im not sure if thats peak and hold or saturated at any rate typeR cams 1mm over valves inkenel ones in the exhaust side precision 6262 turbo edelbrock manifold punched to an even 70mm edelbrock cam gears and 70mm Tbody inline pro manifold vibrant 3inch all the way out if im missin any info let me know im shooting for 700hp i need basemap and suggestion on plugs and i have the new aeromotive 340 fuel pump msd dizzy and ss coil help me out here cuz im putting long block together stat oh ye s300 i have boost selenoid but not sure if it was supposed to come with something to add into ecu and a hondata 4bar map sensor
