Misfire Under Cold Starts?
Posted: Wed Mar 23, 2011 5:20 pm
im not sure what is causing this but here is alil background on it. i drive a 06 supercharged si.
if i cold start my car is weather of -10 to 10 degrees outside the car usually gets a error code sayin its misfiring. also now that it warmer out ive been noticing it again but its only if i let the car set lets say more than 24hrs. its weird becuz when it does the misfire code its a different cylinder each time but usually its either 4th or 3rd cylinder. so that takes the idea of having a coil pack issue. but as soon as the car gets to normal op temp u can hear the difference as the misfiring goes away and starts to work normal again
ive also replaced plugs (ngk 8s), fuel injectors, 02 sensor
ive also messed around with cranking trim n it doesnt seem to fix anything
so if anyone has any comments or suggestion that would be great its kinda annoyin letting the car warm all the way up if its misfiring just so i can drive 10mins later
Anyone else have this issue? hondata have you ever came across this issue?
i will include a datalog also
