B16A2 OBD1 With little mods
Posted: Tue Mar 22, 2011 3:01 pm
by Amroth
Hey there i'm new to this comunity and first i wanted to ask i anybody has a nice map for a b16a2 with some mods or a map with nearly the same setup. would be great i you could help me.
MY Setup is:
B16A2
Ported and Polished B16a1 head with B18C5 internals (retainers...)
b18C6 2000spec Cams
Hondata Intake Gasket
Skunk2 Intake Manifold 68mm
Blox TB 68mm
Cold Air Intake
4-2-1 Header 2.5"
Decat Pipe 2.5"
Full 2.5" Catback
should i run a B18C map with that setup first?
Posted: Tue Mar 22, 2011 6:30 pm
by AREA876
Try this street tune calibration at your own risk
Setup is a B16A2 with
.25 overbore Civic Type R pistons
Type R valve springs
Stock B16A2 cams
Skunk2 intake manifold
DC 4 to 1 header
Fuel pressure was set to 55psi
Posted: Wed Mar 23, 2011 12:15 am
by Luke
we could take a look on that with a wideband, since it's not far away from düsseldorf to dorsten ;)
best regards Lukas
Posted: Thu Mar 24, 2011 5:15 pm
by Amroth
hmm mybe someone who just has a nice working b16 map with simple bolt ons? like header, catback and IM+TB?
@luke
dorsten is not that far from me
around 60km
Posted: Fri Mar 25, 2011 4:20 am
by Luke
i know ;) i'm sometimes at my friend's house in ratingen ;) :D
best regards Lukas
Posted: Sat Mar 26, 2011 12:35 pm
by Amroth
hey there i loaded this b16b map
http://www.hondata.com/forum/viewtopic.php?t=10442
it runs on my engine... no noises no temp problems.
the only thing is that it seems a little bit weak before the vtec (its set to 6000rpm)
but in the vtec it pulls strong
but i think this is only a solution for now and i soon have to go to a tuner and set my car up on a dyno
Posted: Mon Apr 11, 2011 4:19 pm
by Amroth
has anyone a stock b16b map for me?
Re: B16A2 OBD1 With little mods
Posted: Tue Jun 21, 2011 10:06 pm
by CTRSI
i have a calibration for mine that i'll post up it is better then this one with the 6000 vtec set... it has the same ignition maps from the ITR base map but the fuel maps have been slightly tuned
