Hey there i'm new to this comunity and first i wanted to ask i anybody has a nice map for a b16a2 with some mods or a map with nearly the same setup. would be great i you could help me.
MY Setup is:
B16A2
Ported and Polished B16a1 head with B18C5 internals (retainers...)
b18C6 2000spec Cams
Hondata Intake Gasket
Skunk2 Intake Manifold 68mm
Blox TB 68mm
Cold Air Intake
4-2-1 Header 2.5"
Decat Pipe 2.5"
Full 2.5" Catback
should i run a B18C map with that setup first?
B16A2 OBD1 With little mods
hey there i loaded this b16b map
http://www.hondata.com/forum/viewtopic.php?t=10442
it runs on my engine... no noises no temp problems.
the only thing is that it seems a little bit weak before the vtec (its set to 6000rpm)
but in the vtec it pulls strong
but i think this is only a solution for now and i soon have to go to a tuner and set my car up on a dyno
Re: B16A2 OBD1 With little mods
i have a calibration for mine that i'll post up it is better then this one with the 6000 vtec set... it has the same ignition maps from the ITR base map but the fuel maps have been slightly tuned
