K20 direct port dry (30 jet per cylinder)
dnrprojectsvp
- Contact:
Anyone know how much fuel should be added on the nitrous option? I'm running a stock k20a2 with ips k2 cams with rc 750cc inj. I pulled 6 degrees in timing but not sure how much fuel I should start with. I am tuning it on a dynojet but couldn't find any info on this.
Re: K20 direct port dry (30 jet per cylinder)
Dunno if it helps but I ran a 35 hp single shot and pumped in 575 units and ran a very rich a/f.
Maybe start at 2300 and play it from there... or even more if you want to play it safe.
Nitrous rarely causes damage when timing is retarded and its running rich, its when you run lean that the problems occur so best to start rich and lean out to your desired a/f.
