2005 S2K AP2 with Injen CAI, Toda torquie-kun he
miyake
Post by miyake »
Hi,
I've just ordered K-Pro for S2000 @ my local Hondata dealer.
After install of Toda header I would like to start with "Toda header map" but it is avaiable in K-Manager only for 2006-2009 S2000 Dual adapter harness. There are no maps for 2004-2005 AP2.
Can I use this map for start or it is not compatible? If so what I need to make it usable?
Thanks for answer.
I'd suggest using the S2000-AP2 calibration to start with.
miyake
Post by miyake »
I've downloaded latest K-Manager but I can't see any AP2 04-05 calibrations in. Where can I find one?
We only have an AP1 map that is tuned for the 2L engine. You can start with that and add 10% fuel to the overall fuel trim. That should get you close.
The calibrations for the dual adapter setup are not recommended for use on a 04-05.
miyake
Post by miyake »
Thank you for answer.
Could you explain please why calibrations for dual adapter setup are not reccomended for 04-05? And finally is it possible to run vtec as low as 4000rpm at MY05 with Toda header and TP?
