Weird boost creep issue with Hondata BC turned off....
Posted: Wed Feb 16, 2011 6:12 pm
by Axix23
Running a k20z1 with Kpro..
I was under the impression when you disable boost control in kpro with a Hondata Boost Solenoid, it will automatically run off of the wastegate spring b/c its a normally closed application...
I have hondata boost controller disabled in kpro so I can run off the wastegate pressure.. And it creeps "SOMETIMES" in 3rd gear around 3000rpms-5000rpms only....
I have posted a KAL and 2 datalogs....
It works fine when bc is enabled....
It also works fine in 3rd gear above 4000rpms with bc disabled as you can see in datalog 1...
Any ideas Spunkster?
Posted: Thu Feb 17, 2011 6:47 am
by magnEsium
It is pretty rich, and ignition has some room to grow during spool up.
Fix those two and your creep will more than likely be more controlled.
Posted: Thu Feb 17, 2011 7:56 am
by Axix23
thanks, its a street tune that i been working on.... I guess, I still have alot to learn from the master... LOL I will adjust those values u talked about.. I added too much fuel compensation for lower iats b/c i used always run a tad lean during cold temps.. And since its been cold, it dumped alot more fuel...
