Wiring LC-1 Wideband to Kpro
Posted: Wed Feb 16, 2011 10:37 am
I tried to wire my LC-1 to kpro on my PND DC5 ECU.I wire in the E15 of the ECU connectors, it already had a original wire from the car wiring to it.
I change the settings in kpro to using external from ELD pin.The AFR is running in my Kpro but not accurate compared to my logworks.
Tried some offset but did not work well.
Car was idling for some time and suddenly the ecu had no light running and i could not datalog or download any more from the laptop.
Can someone tell me if the yellow wire from LC-1 link to the ECU E15 ELD had cause the Krpo to have problem?
I discconnect the LC-1 wire and it was still the same?
Can someone give me a guide on how to wire the LC-1 to the kpro and what voltage or settings i need to do in the kpro to get the accurate AFR?
