a customer brought me a car to tune but i could not connect to his s300, both the red led and green led were on. we put his s300 board into a known working ecu and it does the same thing, when i removed the s300 i noticed that the capacitors that are supposed to be soldered in were not there. i dont kno if this would cause a problem or not, but with the known working ecu and another s300 board i was able to get his car running.
any help would be greatly appreciated upon visual inspection of his ecu and his s300 nothing appeared burnt.
Cant Connect both leds on
im using the newest version i believe its 1.4.1?
now im having a problem again, now only the red led is on. i have another hondata that works perfect when i put his board in that ecu only the red led stays lit, with the other board it works fine. i noticed it connects but wont upload in the device manager it says s300 ecu. i also noticed the ecu is hot in the corner where the transistor is bolted to the ecu frame and the heat sink gets hot real fast
i dont know what to do anymore
