CEL on P0563 VBU high voltage
equiptcustoms
Post by equiptcustoms »
92 EG hatch
k20a swap
hondata k-pro V1.3.2.0
ECU part number 37820-PNF-A03 2091-310658
Problem CEL on P0563 VBU high voltage
-hi i have an CEL on P0563, i already checked on a topic here in the forum and already checked the wiring on the fuel pump and main relay. Everything is connected properly between the relay and ecu.
- i removed the k20a engine from my previous car honda fit GD with the k-pro, all worked fine, there's no CEL. so i think theres no problem with it being a bad ecu.
- is it ok to drive the car having this CEL.
thanks
Try the ECU in a known good vehicle.
