I have a big issue that i cant find out...
Ok
I have a JDM D15B and the only thing that it has is a Bottom end build up,
Vitara piston
Fj R Spec Rod
and it has a a stock fuel pump
stock injectors 240
stock fuel pressure regulator
AEM Fuel Rail
Head
Stock Valve Train
Bisi LV. 1.2Cam
Stock Camgear
Uego Wideband
Fuel Perssure Guge
Now the thing is that on the Uego gage the AR reads 10.0 and it stays there now on the s300 display it rads .68 and it dose not move. Now on the Uego it moves when you punch the thruttle
What could be the issue i tried other basic maps and it the same, now on the d16a tune map it changes, the uego reads from 10.0-11.2. could i run that base map. But the s300 software display AF reads the same.
