Page 1 of 7
SManager V1.5.3 beta
Posted: Mon Jan 17, 2011 4:09 pm
This release mainly contains changes to update the SManager user interface so that it contains all the features of KManager and FlashProManager.
Changes:
• When multiple copies of SManager are run display a warning and disable concurrent access to the S300.
• Added
Changed Value Highlight for tables.
• Added value base color for Parameter tables.
• Added
Revert to last Save and
Import from Calibration to Table window and Parameters window.
• Added
Datalog Autosave
V1.5.1 changes:
• Added datalog trim functions.
• Added
overrun resume rpm tables.
• Added
Error Reporting.
V1.5.2 changes:
• Added
Erase ECU command.
• Added main
table axis tracing.
• Changed the 3D table tracing to accurately show the cells which are being read.
• Disable print and printer setup if no default printer is present.
V1.5.3 changes:
• Better number display / entry for non-US regional settings.
Posted: Mon Jan 17, 2011 4:43 pm
by blackek4
good job Hondata
Posted: Mon Jan 17, 2011 8:28 pm
by FreshDA9
I like the fact you finally added something to help with the table changes with the changed value highlight. I just tested this out and only problem i see is that it only works on the main table not in the a/f or percent change view's.
Posted: Tue Jan 18, 2011 5:54 am
by AREA876
I would love to see Boost Control (PWM) enable though output A17 (IAB) for a JDM ECU
Ranking Table
Posted: Wed Jan 19, 2011 6:36 am
by Johnny_9
Can we have some sort of ranking table to know what are the features that Hondata would be considering working on for future releases, so we can guess when the features we requested are coming out. Understand you cant do everything at once.
Posted: Wed Jan 19, 2011 9:23 am
There are a lot of factors which go into determining what features to develop, but the main factors are time to develop, benefit to the users, ECU technical feasibility, cost to implement, testing requirements, easy of use, effect on other ECU functionality and resource availability. Our development process is to weight up all these factors and determine what area our resource is best spent on, then work through the development process. Many times a promising idea will dead end due to one of the above factors, and the feature may be put on hold or dropped. While you are welcome to request features (as you have done in another thread), we have found that it is far more efficient if we are in control of the development process and timeline.
Posted: Mon Jan 24, 2011 12:13 pm
by Tsuchinoko
Just for curiosity where is the version 1.4.9?
Is not possible to keep in memory the dtc codes after switch off the ignition?
Thanks by the way for those new upgrades.
Posted: Tue Jan 25, 2011 8:36 pm
by FreshDA9
FreshDA9 wrote:I like the fact you finally added something to help with the table changes with the changed value highlight. I just tested this out and only problem i see is that it only works on the main table not in the a/f or percent change view's.
Posted: Wed Jan 26, 2011 8:48 am
That is how is was designed to work, but I believe I can change it to show under the lambda/percentage change views as well.
Posted: Wed Jan 26, 2011 8:50 am
Tsuchinoko wrote:Is not possible to keep in memory the dtc codes after switch off the ignition?
Check your ECU and make sure the back up power (pin D1) has +12V when the ignition is switched off.
Posted: Thu Jan 27, 2011 4:08 pm
by FreshDA9
Hondata wrote:That is how is was designed to work, but I believe I can change it to show under the lambda/percentage change views as well.
This would be very helpful. Thank you.
Is there a way we could change the target air fuel table manually i would like to be able to step down the columns in air fuel per load and rpm.
And maybe have a lock table option so A/F will not be logged in selected cells, then you can unlock and select another section?
I am only asking since i dont have a load bearing dyno and have to do part throttle on the street it would make it easier on us.
Posted: Tue Feb 01, 2011 11:29 am
by Tsuchinoko
Hondata wrote:Tsuchinoko wrote:Is not possible to keep in memory the dtc codes after switch off the ignition?
Yes i do have batery voltage on that pin with the ignition switched off.
Just to confirm the procedure to see the codes after switch off the ignition, do i need to jumper the 2 pin plug with S300 to see the codes (historic) after i switch off the ignition or isn't needed?
Posted: Mon Mar 14, 2011 5:35 pm
by kesnut
sat down with it this weekend, love the GUI upgrade...
boost control does not work, i when i went back to 1.4.8 it worked. the the software it would say that it was on, put there there was no real output.
and will play with that some more later
on my b20, twice i had a issues the car will lean out for a few sec at a time and then 1min later die. switch off and then back on and it was good again...
the will try and get these in log and sent it to you guys...
keep it up
Posted: Wed Mar 30, 2011 5:51 am
by Johnny_9
Graphics are great; look forward to more features ! i.e. tune-able fuel cut recovery rpm.
Posted: Sun Apr 03, 2011 10:34 am
by FreshDA9
FreshDA9 wrote:Hondata wrote:That is how is was designed to work, but I believe I can change it to show under the lambda/percentage change views as well.
any word on this??
Also can you guys add in a code for serial widebands like my M300te or the innovate? so tired of playing with offsets trying to help customers.
