S3OO ls/vtec help! car stalls sometimes and bogging at 2800
Hi, to all i'm new in this forum, I'm a noob with hondata, I recently bought a Ls/vtec and it cames with Honda s300 the problem is, when i drive the car every day to my work sometimes after 10 mins of ride by highway when i make some stop car stalls or still at idle for a few seconds but after 3 or 4 seconds idle bounces betwen 1400 - low.. and then stalls... idk exactly what is the problem due to car makes it sometimes not always, somedays run smoth and perfect and sometims stalls on every stop. I don't know if it is a problem with temperature, tps, Please help me!. Im attaching a datalog of the car stopped and also im attaching the map of the car.
fyi i bought the swap on USA and now is running here on europe
let me know if its enough or what could be wrong thank you so much to all answers
HI spunkster, many thanks for your repply, do i have to make a new datalog? i was thinking that maybe there is a problem with temperature or with TPS, due to car bogs at low rpm's. If this datalog is useless for you please let me know how to do a proper one im gonna do. Well motor was tuned in a dyno, but motor has been swapped to another car here on europe I've tried to contact tunner but is kinda slow answering so im trying this way.
Yes, sir im gonna do that, I've checked on s300 manager with my map and i want to turn on datalog manually there says, that i can use the scs connector, so like getting error codes should i plug a wires on that connector and drive normally?
im very sorry for the stupid question but i don't have any previous experience with this things....
Good day,
I've performed the datalog with laptop but sudendly s300 loss connection :S and after that s300 is not able to reconnect to ecu i have to unplug and plug again the usb cable to pc and then s300 detects ecu again
I've a datalog of cold start on the morning and a datalog maybe there u can see what is wrong... going out of highway...
also there is a datalog of cold start at noon you can see there how rpms bounces a low rpms....
hope u can help me
do you know why s300 loss conection? :S
hope u can help me
