BoostControl P08JDM A17 at the Neptune in s300j has as well?
Posted: Wed Jan 05, 2011 9:00 am
by HeitorVTiBR
I was looking at the Neptune out of curiosity, I got this picture.
to use the Boost PWM Control in JDM Ecu, could use the entry A17, with the following condition.
"When using the JDM ECU, make sure to disable Output in the IAB IAB Activation Parameters. Also Please Note that the PWM is output on A17 on the JDM ECU is not a +12 v and ground."
has no way to put the option in S300j to select the A17 for PWM control and then not? this would be an option for a next update SManager Software, or would it be impossible?
Heitor.
Re: BoostControl P08JDM A17 at the Neptune in s300j has as w
Posted: Wed Jan 05, 2011 11:21 am
by AREA876
It would be
REAL GREAT if JDM ECU could control boost, please say its in the making =)
Posted: Wed Jan 05, 2011 11:44 am
by HeitorVTiBR
It would be
yes, it asks us to, even if Neptune can, why could not the S300? only he would have to adapt the software to let you select the entry in A17 Boost Control so instead of being only A11 ... I for one, have a solenoid to control boost, but unfortunately my S300 hondata came wrong s300j came with it had to buy a P08JDM New Zealand, which in Brazil, did not think .. then to wanting and needing to use the BoostControl but I can not ... No wait. Thanks
Posted: Sun Jan 09, 2011 9:13 am
by HeitorVTiBR
And then I will not have any answers? I bet that's one doubts that many would like it to be resolved, and it would be appreciated by many for a next upgrade SManager software.
