Bug in 1.1.7.0 (throttle tip in retard)
skier
Post by skier »
if a value is key in the Trim %, eg -10 at gear 2, select the next gear, then select the gear 2 value again.. the value will be-10.0006103515625
apply to all gear. other value like -40, etc also have this problem.
Fixed for the next release - the value was not rounded when you double clicked on a table value.
ajpturbopittsburgh
Post by ajpturbopittsburgh »
Just a question: Why is the throttle tip in retard so low in 4th 5th 6th gears?
And what is gear 0?....Reverse?
It is likely that Honda was using tip in retard to smooth out the lower gears.
Gear 0 is neutral.
Pir8pete
Post by Pir8pete »
Hondata wrote:It is likely that Honda was using tip in retard to smooth out the lower gears.
Gear 0 is neutral.
could we see the word Neutral or N instead of 0 in the next release?
