Does it make a difference which ECU you use for the S300?
hiperformance
Post by hiperformance »
The question is regarding USDM ecu's and the S300.
Is there any difference between using a P72 or p28? Is there any advantage the p72 has over the p28 or any advantage the p28 has over the p72?
Thanks.
Martian
Post by Martian »
P72 has a knock daughter board, P28 does not.
thank you, thank you, I'm here all week
hiperformance
Is that any benefit?
MarkC
Post by MarkC »
Does a P28 from Hondata have circuitry for controlling IAB?
Luke
Post by Luke »
the P28 doesn't have the circuit integrated, but you can create the IAB output with the S300. for that you'll need a relais on the output to manage the current, that is needed to switch the IAB ;) it's explained in the help-file ;)
best regards Lukas
hiperformance
so is there any advantage that a p72 has over a p28? spunkster feel free to chime in with a complete answer.
thanks.
Martian
Post by Martian »
Knock is it. With a P72 you can record knock. Otherwise they do the same thing in every other way.
Luke
Post by Luke »
well, the knock-board is great when using a B16/18... but for other engines?
if you look what the knock-sensor is, you'll see some kind of microphone, which gets its signal out of the engineblock. my opinion is, that the behavior of the blocks is different, clearly: what the knock-sensor shows as a knocking for a B16, needn't be a knocking for a H22, for example.
and knocking cannot be exactly shown at high rpm, because it's simply too loud to egzamin a true or false value ;)
best regards Lukas
MarkC
Post by MarkC »
hiperformance wrote:so is there any advantage that a p72 has over a p28? spunkster feel free to chime in with a complete answer.
thanks.
P72 has Knock Board & (stock wire) IAB control over P28.
hiperformance
Can you record knock with a p28?
no
hiperformance
Spunkster wrote:no
So Spunkster,
If you were given a choice. Which ecu would you prefer to use with the S300?
Luke
Post by Luke »
if costs don't play a role: P72. same as P28, with some special extras. i prefer it, but it's almost double the price!
best regards Lukas
I use P72s
hiperformance
Spunkster wrote:I use P72s
Thanks for the answers!
