help making my wideband work with eld
DOHCAccord
Post by DOHCAccord »
Ok, heres how it is.
plx wideband hooked up, wired up to the eld wire and all works well with the wideband.
I have smanager to use eld input for wideband but no matter i change, alter etc my display will not show the af ratio. the graph does nothing either.
the only thing that does anything is the eld voltage moves.
yes, i can do the math and convert it to af, but i thought the whole point was to have a active semi exact af showing in smanager while it is recording.
please help, am i wrong? am i doing something wrong with this?
AREA876
Post by AREA876 »
Did you disable ELD in the Misc. parameter?
You should have only your wideband connected to D10 ELD.
To change from Lambda to AF go to options >settings>units and then you can change from Lambda to AF.
Hope this Helps
Also in the sensor list set a min and max of 10 and 20 for the AF.
DOHCAccord
i have tried disabling eld and not disabling it.
the sensor is set to air fuel
min is 10 max is 20
and when its in the graph or display it reads like lambda .88, 1.06 etc
all i want is it to read 14.89, 12.4 etc so i can start the offset process to ge it to match my wideband display
Did you also change the settings under Options, Settings?
DOHCAccord
yep. everything is just as above
Did you actually cut the wire you connected the input to?
DOHCAccord
i found the issue, is the sensor setup, the af was registered as lambda, changed it af and all is well.
thank you all for your help
