Serial Output - Injector Duration
Posted: Sat Nov 27, 2010 4:19 pm
Hi,
I have built a microcontroller interface between the serial output of my Hondata ECU and the serial input of my datalogger system. All works fine, except I can't make sense of the injector duration data format in the serial stream, and I need this for some fuel consumption calculations.
KManager.chm says:
Byte Contents
9-10 MAP (mbar, LSB = 1 mbar)
11-12 Injector duration
13 Ignition timing (degs + 0x80, LSB = 0.5 deg)
So, for injector duration, bytes 11 and 12, it doesn't document the data structure, although it does for all the other values. From the two examples:
11-12 0CAC Inj 12.964 ms
11-12 079D Inj 7.784 ms
It is still not obvious. Please let me know how to do the conversion from the two serial data bytes into injector duration in milliseconds!
Thanks.
KManager.chm says:
Byte Contents
Thanks.
