Hey guys, I have a P75 (non vtec )ecu with s300 installed and I am just wondering what I will need to do to run a B16a with this ecu/s300 combo. Will I need to add the vtec components to the ecu or is there a way to change the vtec output signal to run on a different pin?
Any help would be greatly appreciated, Thanks!
Ryan
S300 on P75, want to add VTEC Need help!
ok, after some research I found my answer, Although I am unsure of what to buy for a relay. Radioshack/ local parts store carry one that would would work?
It seems as though people have problems trying to wire the relay up correctly. Is there any tips or tricks before I start? Or would it just be easier to convert the ecu I have to vtec with a conversion kit from moates or xencron? I think I would feel more comfortable converting to vtec since I have done it to a few PO6's.
Ryan
Ryan
V-Spec race development
Re: S300 on P75, want to add VTEC Need help!
Can you share what did you do to make the relay work? What pin input did you use etc. Which relay did you get and where can I get it from? thanks.
