plx voltage offset
niall
plx voltage offset
Post by niall »
has anyone had to use the voltage offset with a plx wideband plugged into the hondata s300?
Yes, this is used for all widebands.
niall
hondata s300
Post by niall »
i wasasking as I have the plx wideband but without the gauge as its plugged straight into the s300 so was wondering if the afr are correct as they said it was self calibrationg
Without having a gauge there is no way to make sure that the value you are datalogging is acruate with what the wideband is reading. You may be able to use a multimeter to get the output voltage and then calcualte the AF and compare it, but that does require equipment and conversions.
niall
plx
Post by niall »
thanks
