S2k P0720 error with new KManager
Boofster
Post by Boofster »
Using KPRO dual '06 S2000 spec.
I started throwing P0720 after I upgraded from 1.3.8 to 1.4.1
Is there an issue with this?
It happens randomly when going into idle. Normal is ~1000 rpm but it surges to about 1200, stays there for a second, throws the code, and drops back to 1000.
"P0720 Output Speed Sensor Circuit Malfunction (Transmission)"
Da Boost
post a high resolution and focused picture of the inside of the K-Pro ECU
Boofster
Post by Boofster »
Here you go:
http://www.xtinct.com/Boofster_KPRO.jpg (3.2mb)
I checked with a buddy on s2ki.com with the same setup and he's having the same issue with the last software update. Throws the same code and all.
I can ask him to post here...
Da Boost
Also post a picture of the bottom of the circuit board witht he ECU removed from the case.
Boofster
Post by Boofster »
Spunkster wrote:Also post a picture of the bottom of the circuit board witht he ECU removed from the case.
I'll do it when I get home today. Are you looking for something that burned out? The box hasn't been touched since it came from you guys.
Da Boost
kb58
Post by kb58 »
They want to know the serial number of the board, and maybe the board rev.
Mid-engine K24 turbo Locost, http://www.midlana.com
Boofster
Post by Boofster »
Here's the bottom of the board:
http://www.xtinct.com/Boofster_KPRO_bottom.jpg (3.3mb)
Da Boost
The error code you are getting is being generated from the stock ECU, not the K-Pro ECU. Neither the the K-Pro nor the software will not cause this. This is either a wiring problem or a sensor problem. THe K-Pro ECU has been modified properly for the dual harness.
Boofster
Post by Boofster »
Sensor was replaced with new oem unit.
Problem is less frequent but still there. After random neutral shift, idle goes to normal, surges a little, throws code, and idle goes back to normal.
Also experienced by others:
http://www.s2ki.com/forums/index.php?showtopic=821586
Recently I found out some FlashPro users of the SOS superchargers are having deceleration revs going up by themselves. This could be the same issue. I am experiencing some surges while shifting at speed as well.
Da Boost
eternallx
Post by eternallx »
I've been told that you guys are now looking further into this issue... is this true?
As per the post made Nov 11, the error code is from the S2000 ECU, and cannot be caused by a software update to the KPro.
Boofster
Re: S2k P0720 error with new KManager
Post by Boofster »
Could this have something to do with the Parameters > Misc > Speed Sensor options?
Which checkbox should be clicked? What should the speedometer correction be set to?
Da Boost
