iat problem
b.r.i.a.n.
iat problem
Post by b.r.i.a.n. »
i'm using version 1.1.6.7. i'm on the dyno and i'm doing another pull and i get a major power loss as the rpms climb. the only change i had done was fuel. i look at the log and i see the iat's climb rapidly out of no where as the rpm's increase.
i flashed the ecu again and the problem went away. it happened again later on. i did another pass before flashing it this time and it got worse. it was reading iat's in the 100's. i flashed it once again and the problem went away.
i made a few more passes and i was done and the problem never returned. is this a glitch??? i posted 2 logs showing the problem and a log showing what it read when it was reading right.
2003 Civic Si - 241 whp/166 tq - all motor - sold
2002 S2000 - 234 whp/155 tq - e85 powered :D
2006 TSX - daily driver
This looks like fairly normal heat soak to me. Look at the ECT temps.
