VTC for cruising (columns 2 - 7 and 1500 - 4500 rpm)
Posted: Thu Nov 04, 2010 10:18 pm
I'm in the process of tuning my own personal Kpro'd car and getting it ready for my Ontario Canada Emissions test. When reading the Kpro instructions it mentions that a VTC of 30 is great for the cruise RPM and columns.
Kpro Instructions
I have tuned the A/F at 10, 20 and 25 VTC in columns 2 - 7 and 1500 - 4500 rpm and was wondering what is recommended for both emissions and fuel economy. I've currently got it set at 18 vtc, but would like to get a little advice before you e-test.
Thanks, Marc[/quote]
Kpro Instructions
Flashpro InstructionsAt cruising rpm and load (columns 2 - 7 and 1500 - 4500 rpm) set the cam angle to around 30 degrees. The EGR effect of the extra camshaft overlap will reduce emissions and improve fuel economy at cruise.
I'm running a K24a2 and noticed that the base maps for the TSX have a VTC of 10 for the cruising RPMS. Plus I still only have the 25 degree VTC gear so 30 is out of the question :)At cruising rpm and load (columns 2 - 7 and 1500 - 4500 rpm) set the cam angle between 15 and 30 degrees.
