Kpro Instructions
Flashpro InstructionsAt cruising rpm and load (columns 2 - 7 and 1500 - 4500 rpm) set the cam angle to around 30 degrees. The EGR effect of the extra camshaft overlap will reduce emissions and improve fuel economy at cruise.
I'm running a K24a2 and noticed that the base maps for the TSX have a VTC of 10 for the cruising RPMS. Plus I still only have the 25 degree VTC gear so 30 is out of the question :)At cruising rpm and load (columns 2 - 7 and 1500 - 4500 rpm) set the cam angle between 15 and 30 degrees.
I have tuned the A/F at 10, 20 and 25 VTC in columns 2 - 7 and 1500 - 4500 rpm and was wondering what is recommended for both emissions and fuel economy. I've currently got it set at 18 vtc, but would like to get a little advice before you e-test.
Thanks, Marc[/quote]
