Faulty Hondata Boost Controller?
Posted: Thu Nov 04, 2010 2:44 pm
by Axix23
So, I have my Hondata boost controller turned on and using only 0% duty cycle and its spiking the boost well above 15+ psi when my wg spring is only 7 psi... With the bc turned off, its only around 9-10 psi... Whats going on here?
I am pretty sure all the wiring is right...
Faulty boost solenoid? Is there warranty on this?
Anybody else have these issues?
Posted: Thu Nov 04, 2010 2:58 pm
You cannot use 0% or 100%. Use something other than that.
Posted: Thu Nov 04, 2010 6:11 pm
by Axix23
Spunkster wrote:You cannot use 0% or 100%. Use something other than that.
Ok, I will try 1% then. Also on boost solenoid activation psi? What level should I use? I am running a 7 psi wg spring..
Posted: Fri Nov 05, 2010 7:27 am
Use about half the spring pressure for the activation pressure.
Posted: Fri Nov 05, 2010 11:09 am
by kb58
No, 1% won't do anything either. You have to remember it's a mechanical assembly with mass and potentially some stiction, so you won't get any movement until up around 30-40% or so. Just experiment with it, you'll figure it out.
Posted: Fri Nov 05, 2010 12:01 pm
by Axix23
kb58 wrote:No, 1% won't do anything either. You have to remember it's a mechanical assembly with mass and potentially some stiction, so you won't get any movement until up around 30-40% or so. Just experiment with it, you'll figure it out.
I am not trying to increase boost that much. Maybe +2-3 psi. If 0% duty is causing me 15+ psi, I hate to see what 30-40% duty does to it...
Posted: Fri Nov 05, 2010 12:05 pm
by Axix23
The reason I even tried using 0% duty is b/c the Hondata website said to do it:
"Connect the boost control solenoid, enable the ECU output and set the duty cycle to 0%. Record the boost level. Typically there should not be more than a 1 lb increase from the baseline.
Add 5% to the duty cycle and record the boost over the rev range. At around 20% duty cycle the boost level should start to increase with each run. Record the duty cycle and corresponding boost level. If the boost spikes or falls off, check the solenoid plumbing."
start with 15% and incrementally increase it.
Posted: Fri Nov 05, 2010 12:08 pm
by Axix23
Spunkster wrote:start with 15% and incrementally increase it.
ok, I will try that. All my plumbing is right, I double-checked it with the hondata bc diagram that yall e-mailed me.
So set Fixed Duty Cycle to : 15%
and also set duty cycle limits to : mim: 15% and max: 15% ??
Posted: Fri Nov 05, 2010 12:30 pm
leave the min and max at the defaults of 15 and 85.
Posted: Fri Nov 05, 2010 1:56 pm
by Axix23
ok, thanks.. Tried the 15% and worked perfect.. Hit around 12 psi and no spikes... Thanks kdb, spunkster, and hondata for your help.
Now, I just gotta figure out how to setup boost by gear... LOL
Here is my current KAL and datalog with bc on.. @ 15%
Posted: Fri Nov 05, 2010 2:17 pm
by Axix23
Hondata wrote:Use about half the spring pressure for the activation pressure.
I am running a 7 psi spring. What would happen if I did 2 psi on the activation pressure?
All that is, the bc will kick on @ 2 psi to increase boost, right?
Posted: Fri Nov 05, 2010 3:49 pm
by Axix23
And also, what do I select for Low/High Boost Control? I am not using a switch, so which one do I select to have low boost(by gear) on all the time? select Always on?
Posted: Fri Nov 05, 2010 9:09 pm
by Floppie
It won't further increase boost at that point, because the wastegate isn't open at all. All the boost controller does is apply pressure/vacuum to the wastegate spring to make it open earlier/later.
Posted: Fri Nov 05, 2010 9:35 pm
by Axix23
I am trying to get my boost by gear setup in my kpro..
I got 2 questions: Under low/high boost control, what selection do I need to pick? (I am not running a external switch), so if I select "always on," does this mean, HIGH BOOST tables are always used?
And if I select "always off," does that mean LOW BOOST tables are always used?
And the duty vs pressure tables.. What values do I enter or should i leave it with the default values on?
