SManager not downloading calibration from ECU
Posted: Sun Oct 24, 2010 4:34 pm
Per FAQ:
Not possible
Again, not possible
- what sort of vehicle you have
1994 Honda Accord H22A Turbo
- what sort of ECU you are using
P06 w/ S300
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
Non-VTEC ECU with relay (works fine)
I installed my S300 on Thursday night and tuned my car Friday afternoon at a local shop. We tried to use my laptop to tune but it keeps loosing connection with the ECU, then SManager locks up and crashes.
It's a Dell D400 with a GB of ram, new HDD and a fresh install of XP running the newest build of SManager.
The tuner switched to is laptop to finish my Accord since mine wouldn't work, I don't know what build of SManager he's using.
Car is tuned and runs fine, but I'd like to be able to adjust my idle, and I can't. The Dell will run SManager, it sees my S300 and will connect and run realtime, but I cannot change any parameters (greyed out) and I cannot download the calibration from the ECU. When I click online, download, I get the warning, click ok, then it just sits there saying receiving, the ECU is connected because I can see values change, but it hangs and has to be shutdown (Ctrl+Alt+Del).
What's the deal?
Not possible
Again, not possible
P06 w/ S300
What's the deal?
