Innovate LM2 serial ( usb ) input
Posted: Sun Oct 17, 2010 12:29 pm
by jordancivic
Is it possible yet to use the Innovate LM2 serial connection to log AFR within Smanager ?
Posted: Mon Oct 18, 2010 7:07 am
by Luke
the LM2 has a direct wideband output which you can put into the S300 and log.
take care, that you also get GND properly, since the outputs and inputs are differential.
the other way is also possible: logging several outputs (IAT;ECT;MAP; RPM) with the LM2 ;)
best regards Lukas
Posted: Mon Oct 18, 2010 12:04 pm
by jordancivic
Im not talking about the analog outs, of course i can use these, im talking about a serial out so there is no issues with voltage offsets and random readings. Plug in the USB from innovate, LOG, job done.
I know this is possible, just wondering if Hondata are working on it and if/when it is likely to be available.
Posted: Mon Oct 18, 2010 12:42 pm
There are currently no plans for this.
