Need B18cR Skunk2 Pro3 Calibration plzz
spoonskywalker
Post by spoonskywalker »
I need base map for following setup.
Skunk2 Pro3 Cam
Skunk2 Header and Throttle Body
Stock piston
Stock Injector
Thank in advance
Luke
Post by Luke »
i recomend to change pistons AND injectors.
i've tuned a stock B16 with a built head and stage 2 cams with 370cc injectors.
as far as hondata show the injector duty, those injectors are maxed out :-|
best regards Lukas
