does any body have a map for this setup
sureshot
Post by sureshot »
b18c, precsion sc61 turbo,550cc rc injectors,s2 stage 2 tuner vtec cams, s2 intake mani,s2 70mm throttle body . supertech springs and tit retainers,stock bottom end, s2 pro cam gears iam trying to find a map for 10lbs psi...it has been tuned for 5-7psi ....does any one know if i can turn up the boost without re tuneing...my manual boost controller faild so i have to run spring pressure 5-7 psi,but i can put in a 10psi spring would that be ok on the engine with a 5-7 lbs tune or will it mess the engine up
well im trying to bulid my car but i keep haveing run ends with unfortionate things in life
eg6b20r
Re: does any body have a map for this setup
Post by eg6b20r »
sureshot wrote:b18c, precsion sc61 turbo,550cc rc injectors,s2 stage 2 tuner vtec cams, s2 intake mani,s2 70mm throttle body . supertech springs and tit retainers,stock bottom end, s2 pro cam gears iam trying to find a map for 10lbs psi...it has been tuned for 5-7psi ....does any one know if i can turn up the boost without re tuneing...my manual boost controller faild so i have to run spring pressure 5-7 psi,but i can put in a 10psi spring would that be ok on the engine with a 5-7 lbs tune or will it mess the engine up
Its not a good thing to run more boost without proper tuning it for the target boost. the more boost, the more air and you have to compensate with fuel and ignition to get the more out of it.
It's your car , you do as you please, but def not good to do it not tuning.
