Page 1 of 2
number 1 showing 100 knock count
Posted: Sat Oct 09, 2010 11:17 am
by terryl
Hi just thought i would try my new flash pro out and do a data log on my standard euro 2008 s2000, it reads 100 knock count on number 1 cylinder straight from firing it up and keeps the reading the whole data log - no knock on any other cylinder - showing some knock retard as well in places - is this normal ?
Thanks .....
Posted: Mon Oct 11, 2010 10:20 am
You must post the calibration and a datalog showing the problem.
Posted: Mon Oct 11, 2010 3:34 pm
by terryl
datalog enclosed car is standard 2008 s2000 euro 25k miles
Thanks .....
Posted: Wed Oct 13, 2010 4:09 pm
by terryl
Could this be a error in flashpro software ? ecu is stock when datalog taken . uploaded stock setting and still the same reading #1 100 knock count
Thanks ..........
Posted: Wed Oct 13, 2010 4:23 pm
Spunkster wrote:You must post the calibration and a datalog showing the problem.
Posted: Wed Oct 13, 2010 4:33 pm
by terryl
Hi posted datalog and now calibration - hope this is ok - am new to this sorry
Thanks..........
Posted: Thu Oct 14, 2010 11:20 am
Go to online, and click on clear DTCs, then start datalogging and keep datalogging while starting the car. Send that datalog to us
Posted: Fri Oct 15, 2010 2:24 am
by terryl
As Requested - thanks for your help
Posted: Fri Oct 15, 2010 2:20 pm
It appears you have not uploaded using the most recent version of software. Upload your calibration to the ECU using the most recent beta version of our software from the website and then when you datalog you will not see the incorrect knock count.
Posted: Mon Mar 21, 2011 4:49 am
by Croc999
Hi,
same problem for me.
Euro S2000 2007.
Got the Euro Flashpro and used the lastest software version that you have on site (1.1.7.4).
I didn't flashed the ECU yet - but locked on ECU and collected logs.
Knock count is constant 100 and stays the same after ignition/engine off.
pls help.
Thanks,
Gennady
Posted: Mon Mar 21, 2011 4:52 am
by Croc999
one of the logs is attached.
Posted: Mon Mar 21, 2011 6:19 am
by terryl
Hi I am using 1.1.6.7 software and all is ok on this - just thought i would let you know
Cheers Terry
Posted: Mon Mar 21, 2011 6:25 am
by Croc999
thx for the info - i see you still subscribed on this thread :wink:
so what resolved this for you? switching for a newer software version?
or soemthing else/additional?
Posted: Mon Mar 21, 2011 6:31 am
by terryl
1.1.6.7 was the beta at the time and this cured it from the previous software - i am guessing - but i think they may have left the cure out in the latest release ? hondata are very helpful so they will sort the issue out im sure - for now i will stop on old soft ware :)
Cheers Terry
Ps Go TURBO - awesome car now
Posted: Mon Mar 21, 2011 6:37 am
by Croc999
i actually have 1.1.6.7 installation EXE that i downloaded at last December.
i'm just not sure that i can use it as Flashpro box upgrades itself with a new software - so maybe it's not OK to downgrade it.
let's see what's Hondata will say.
thx anyway !!!
Gennady
p.s. had turboed miata in the past but i like S2000 as it is :)
and it's already too fast for local roads...
