Maxing out ID 1000cc injectors at 6psi? help...
hachirokukid
Post by hachirokukid »
I'm trying to tune a 02 Rsx type S, Peakboost t3/t4, 1000cc ID injectors, 255lph and stock return less fuel rail.
AS soon as vtec (6000) comes on and pass 6800, it goes scary lean, 16ar 17ar.
I included the map and two logs. The map is rough and needs more tuning but at WOT pass vtec its maxed.
I don’t know if it has to do with fuel trim or something. Any help or insight would be greatly appreciated.
Check the fuel pressure to see what it is doing. It sounds like you have very little pressure.
hachirokukid
it was a fuel pump problem...
thanks again guys!!!
mcmanus9442
Post by mcmanus9442 »
weird....my rsx is doing the same thing with rc750s stock returnless
i added a 6AN feed and 6AN return with a regulator. Base is set @ 52PSI. Still did the same thing...now im thinking maybe its my pump too..
