Flahpro USA base maps - can they be used in euro ecu
Posted: Wed Oct 06, 2010 10:05 am
by terryl
Hi there - just wondering if anyone knows if we can use US base maps in our Euro cars - i know usa cars are 2.2 but i dont see why these maps cant be used as a starting point for us - as the map i am looking at runs same injectors i am going to be using rc650s - hondata say use the dead times they use in usa maps
Cheers .....
Posted: Wed Oct 06, 2010 11:07 am
Yes you can, but you may get some errors due to the difference in the vehicles and you may not be able to disable the errors.
Posted: Thu Oct 07, 2010 7:44 am
You can do this, however is not recommended to do so.
Posted: Thu Oct 07, 2010 8:02 am
by terryl
Thanks for the reply - can i ask why it is not recommended ?
Thanks again
Posted: Thu Oct 07, 2010 9:18 am
Because you would be using US code in a Euro ECU. The hardware is different, and the behavior may be unpredictable.
Re: Flahpro USA base maps - can they be used in euro ecu
Posted: Sat Feb 28, 2015 8:53 am
by S2000443
What about a European start map for a rotrex supercharger on a US 06 car?
Posted: Tue Apr 28, 2015 6:23 am
by Bad_One15
how about using fuel,ignition, WOT maps of US Specs to EDM specs?
will it create some issues?
TIA...
